idle problems!!! help
for some reason when my car idles the rpms go up and down from 1000 to 200 rpms and once the car turned off on me but started rite away when i turned it on again.
someone told me it had to do with running rich
does anyone have any solutions?
Won't be a vac leak if it's surging. Surging is due to a rich condition, meaning, not enough air is getting in, or too much fuel. A vac leak allows more air to get in, causing the idle to go up.
Try creating a vac leak and see what happens. Just pull a vac line off with engine running and see if it cleans itself up a bit. Could be your IAC not allowing enough air into the engine.
