Vibration Damper
Old Aug 16, 2009 | 07:31 AM
84GT350's Avatar
84GT350
Default Vibration Damper
I have an 85 coupe that still has the 7.5 rear in it. I recently did a 5 lug conversion and put 4.10's in it. My question is, that steel vibration damper that hangs from the rear around the pinion area, is that needed? I pulled it off when doing the gear set but should i put it back?
Old Aug 16, 2009 | 03:56 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
its not needed but does help to dampen vibrations
Old Aug 16, 2009 | 04:23 PM
mattdel's Avatar
mattdel
You'll find the integrity of your rear end to be much longer with it on. Vibration does not do anything positive for bearings or clearances. Leave it on.
Old Sep 18, 2009 | 07:53 AM
84GT350's Avatar
84GT350
Thanx guys.. I put it back on..
Old Sep 18, 2009 | 09:09 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
You'll find a lot of different opinions on this Scott. FWIW, mines still on the car.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
