Motor Mount Problems
Old Sep 4, 2009 | 08:42 PM
Stangs4me's Avatar
Stangs4me
Default Motor Mount Problems
So I just picked up a '93 5.0 LX with 150k miles and I'm starting to work on her so the first things to be replaced are motor and transmission mounts. Working with my Toyota mechanic neighbor, we replaced the tranny mount without a problem but can't seem to get the motor mounts freed.
We remove the nut from the bolt going through the K-Member without a problem but when we attempt to raise the engine by jacking at the oil pan, the whole car comes up. So we tried removing the other side's K-Member nut and same thing happens. The funniest thing is that when we use a crowbar on either side, we can lift the engine off the K-Member without a problem. It almost seems like there is a 3rd mount holding the engine to the frame somewhere else.
Any suggestions before I give up and take her to my mechanic?
Old Sep 4, 2009 | 09:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
un bolt the mounts from the block = 2 per side then jack it up and wiggle them out
Old Sep 4, 2009 | 09:07 PM
Stangs4me's Avatar
Stangs4me
Forgot to say, we did that too and it didn't help.
Old Sep 4, 2009 | 09:13 PM
mjr46's Avatar
mjr46
jack the motor as high as you can, place the jack and block of wood on the bottom of the flat portion of the bellhousing, with the 2 bolts out and nut off they will come out, I have never had an issue, it'll be tight but it can be done
Old Sep 4, 2009 | 09:15 PM
Stangs4me's Avatar
Stangs4me
The motor doesn't jack up. It just lifts the whole car.
Old Sep 4, 2009 | 09:17 PM
mjr46's Avatar
mjr46
loosen header flanges up and see if that is causing the bind, make sure that the bellhousing is not bound already against the firewall
Old Sep 4, 2009 | 09:23 PM
Stangs4me's Avatar
Stangs4me
That'll be the first thing I do in the a.m.
thesambox
Aug 19, 2015 09:39 PM
joe73Qcode
Aug 15, 2015 09:49 AM
classic69FB
Aug 12, 2015 11:58 PM
Itstbrown
Aug 9, 2015 03:49 AM
