possible valve float??
Old Jul 14, 2005 | 02:20 AM
5.0sTheWayToGo's Avatar
5.0sTheWayToGo
Default possible valve float??
I recently installed crane 1.7 energizer rocker arms and new crane valve springs. got the car running good and took it to the track last friday. it ran good 14.3 @96 mph. Well the other day i was messing around with a mach 1 and we droped and when i droped into 3rd the car back fired really bad so i just let off. then i heard a ticking noise. the noise turned out to be a header gasket that i just replaced. but now it seems like my car doesnt pull as hard as it was when i first got everything installed. seems like at 4800 it just falls off. yes i know on a stock 5.0 cam thats usaully where it falls off hard. but when i was running at the track it was pulling all the way up to 5200 at least. i do hear a ticking noise that has gotten louder than when i first had everything on the first night. im just wondering if i could be getting valve float or if that back fired had something to do with it or was it just random. thanks for any suggestions. oh and when i did the springs i got each cylinder to TDC the best i could.
Old Jul 14, 2005 | 11:43 AM
5.0sTheWayToGo
Default RE: possible valve float??
nobody?
Old Jul 14, 2005 | 11:46 AM
vfast's Avatar
vfast
I ♥ Acer
well I would check to see if you bent a push rod and readjust the valves,also recheck timing
Old Jul 14, 2005 | 11:51 AM
5.0sTheWayToGo
alright.
Old Jul 14, 2005 | 02:14 PM
Quik's Avatar
Quik
what lift were your springs good for? also told you before to check them out. you could of possibly damaged a valve
Old Jul 15, 2005 | 12:27 AM
5.0sTheWayToGo
i dont know i got them at a speed shop and the guy set me up with the springs to match the rocker arms. all i know is i spent like 140 bucks for crane springs. and got riped off for the price. i doubt any valves are damaged. car stil runs fine i just think im getting valve float at high rpms.
Old Jul 15, 2005 | 01:32 AM
5.0sTheWayToGo
i did the best i could to set each cylinder to TDC when i installed the springs and rocker arms. my question is could something have gotten messed up. how often do you need to readjust your valves?
Old Jul 15, 2005 | 02:46 AM
silver91gt's Avatar
silver91gt
when you put the new springs on, did you leave on those stock washers under the springs?
I am redoing my heads and would like to know.
Old Jul 15, 2005 | 04:09 PM
5.0sTheWayToGo
yes i left those on. i have stock heads i just changed my valve springs and rocker arms.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
