jack point
Old 10-16-2009, 08:08 PM
1988GTstang
1988GTstang's Avatar
Default jack point
ok dumb question and if its in the wrong section i apologize my jobs comp wont let me go anywhere else...i kno ur not supposed to jack the car on the unibody rails or wutever u wanna call um cuz it will cause fender issues but once the cars jacked up can u place jackstands there to hold the car or will that too cause issues?
1988GTstang is offline
Old 10-16-2009, 08:15 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Use the frame rails. You can jack the car up there or by using the k-member and the rear diff. Never jack or support the car by the pinch weld.
Boss_Hotrod is offline
Old 10-16-2009, 08:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
front of frame rails and torque box area in the rear or on axle tubes
mjr46 is offline
Old 10-16-2009, 09:37 PM
1988GTstang
the frame rails isnt wut i was asking bout right?
Old 10-16-2009, 09:44 PM
mjr46
mjr46's Avatar
frame rails, unibody rails, same thing jack the car up there, you'll be fine!!
mjr46 is offline
Old 10-16-2009, 10:20 PM
Boss_Hotrod
The frame rails are the wider rails about 1 ft into the car. The pinch weld is at the bottom of the rocker panel, about 2 inches under the car.
Old 10-16-2009, 10:43 PM
1988GTstang
oooo the pinch welds are the real skinny rail somewhat under the door almost?
Old 10-17-2009, 10:03 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Yea its where 2 pieces of metal are together is the pinch weld. For the best support if you do put a stand on the frame rail be sure to place them more toward the front or toward the rear most part of them so it doesn't push up into the floor pan. I'm sure you can see what I am talking about if you looked at your car.
projectresto83 is offline
mtgldr
02-03-2024 09:00 PM
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
09-25-2015 09:06 AM
Quick Reply: jack point
