Trick Flow?
Old Jul 19, 2005 | 03:27 PM
Quik's Avatar
Quik
Default RE: Trick Flow?
damm, TFs are great heads and will get the job done. you can have the best heads in the world but if you cant use them they are wasted. AFRs are good but for the price difference, ill just work over teh TFs. AFRs arent all that great as ppl praise. you should know that. ppl with AFRs go 13s ppl with stock heads go 12s. ppl with eldeys go 14s and ppl with TF 10s.......its all in the combo not just hte heads
ORIGINAL: stangpower96
Trick flow has been know to make good products for the money,but i never heard anything about there crank kits,are they forged or cast and as for the heads they do make decent heads but i would look into something alittle better"eldey's,AFR'S,etc." if was going to spend that type of money,but that IMO.
Old Jul 19, 2005 | 05:21 PM
bufwrastler215's Avatar
bufwrastler215
i have hered that tf heads cant handle power adders very well. is this true?
Old Jul 19, 2005 | 10:55 PM
Motorman's Avatar
Motorman
The plan is to run the trick flow top end combo on a Ford motorsports 347 stroker based on the 5.0 block. Was looking in summit and saw it would run me a little over 4 grand and I would have a new block, heads, intake, cam, timing chain for not a whole lot of $$. Course thats assuming all the ***. are still good on the fact block. Would most likely spring for a new Mildon oil pan and pick up. Then use the dist and such off the fact until I can get a MSD ignition system. Let me know what yall think
Old Jul 20, 2005 | 03:39 AM
Quik's Avatar
Quik
well you tell me. 331 with TFTW heads and 15psi making 540 ish at the wheels in a JYTT 91 LX. cause thats what my budd got in his stang. his old setup can be found on www.turbomustangs.com as Rob and his 91 yellow LX
ORIGINAL: bufwrastler215
Oct 26, 2015 05:01 PM
Luke9222
Oct 22, 2015 11:55 PM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
Sep 10, 2015 08:39 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
