Problem removing bellhousing
Old Nov 28, 2009 | 11:40 AM
jeraldjcook's Avatar
jeraldjcook
Default Problem removing bellhousing
For some reason I can't get the bellhousing off the engine block. It's a 1993 5.0 with a T5. All the bolts are removed, front and back of the bellhousing. Chilton's says there are two dowels on each side of the bell housing, that's all that's left. I've marked the dowels in red on the photos. Are these the dowels? I've checked the front and back of the dowels and they're aren't any bolt heads or allen wrench heads on them so I'm assuming they're press fit. Any ideas?
Old Nov 28, 2009 | 12:34 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah, those are the dowels. You may have to get a screw driver in between the 2 pieces to pry them apart.
Old Nov 28, 2009 | 01:59 PM
mustangsneverdie's Avatar
mustangsneverdie
have you took the starter off yet looks like I'm seeing the end of the bolt
Old Nov 28, 2009 | 03:02 PM
jeraldjcook
Yeah the starter is out. After 30 minutes with a rubber mallet it's slowly starting to come off. I'm letting the WD-40 work its way into the dowel holes and I'll give it another go. Thanks for everyone's help. I was pretty sure those were the dowels but with all the surprises this car has had I wouldn't be shocked if the previous owner had busted off a couple of bolt heads and just left the bolts in there.
Old Nov 28, 2009 | 04:20 PM
AdderMk2's Avatar
AdderMk2
Banned
FWIW, WD40 ISNT a lubricant... its a water dispersant..
you should be using a penetrant like PBlaster
Old Nov 28, 2009 | 06:33 PM
Bubba 95SN's Avatar
Bubba 95SN
Sea Foam makes DEEP CREEP. Spray that on and will fall off by itself. About $12 a can. Use it on well drilling rig lots of mud, water, and rust.
Old Nov 28, 2009 | 10:53 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
PB blaster for the win!!!!!!! and a prybar!!!
Old Nov 28, 2009 | 11:23 PM
jeraldjcook
Two recommendations for PBlaster is good enough for me. It's already on my "to buy" list for my next run to the store. I did finally manage to get the bell housing off, along with the pressure plate and flywheel, but then I ran into my next hurdle.
Leaking oil pan gasket
Old Nov 29, 2009 | 08:19 AM
mjr46's Avatar
mjr46
I would just clean it all down really well and not worry about it to much right now and monitor the leakage, it won't be any more work later........but do replace the rear main seal while your in there
spamedic
Sep 9, 2015 12:15 AM
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 2, 2015 04:12 PM
