Smog lines reinstall questions- 95 GT
I have a different scenario than most smog questions on here. I tried to search but got really nowhere but with how to remove the smog stuff. Well, in my case I have to reinstall the OEM smog lines. I took the lines off several years ago and got rid of them. Now, the car needs to pass smog for registration and I want to just find some OEM equipment and reinstall it. The reason I need to do it is because I has BBK shorty headers installed a long time ago and when they were installed, the passenger side header was capped off. I don't know what went there. I think maybe a factory line for the smog lines. Well, the cap blew off DURING the smog check. Simply amazing. So, then the guy started looking and figured out that I had the smog lines removed and now I have to put them back on to smog it. My questions are 1. does anyone have all of their factory smog equipment from a 94/95 5.0 they want to sell for cheap? I don't need the pump, but everything else, meaning the tubes and valves. 2. Does anyone know where to find a DIY with pics for a smog pump uninstall so I can reverse it? I tried to look for a DIY and got nowhere. Any help would be much appreciated. The most important part is getting the parts. Thank you.
eBay would be your best bet for parts, or someone local that removed all the junk.
I have a picture on my home computer of the layour for the EGR junk. If no one posts it up before I can, ill get it to you later today.
You can pass w/o the lines. I'm running the smog pump with just ONE line going from the pump to my midpipe. I passed emissions easily and im not running the line to the heads or anything.
Shiat, i didn't read your setup, you might need everything to get the emish readings as low as you can.
it's all pretty basic
shorties should have no bung tapped though, the o2 sensor goes in the h-pipe, long tubes have the o2 sensor in them though
the y-pipe comes off the rubber and goes to the back of the heads, did you plug the smog pump...it would make noise if you didn't so i'm a bit confused
i guarantee you can find it all cheap though... just be aggressive
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
