problem with rings!
Old 02-02-2010, 12:02 PM
mustang anthony
mustang anthony's Avatar
Default problem with rings!
Long story short I am rebuilding a 1990 5.0 non HO motor to go into my 1968 coup. The problem is I keep getting the wrong rings. The pistons I have are flat tops (original to the motor) with 1.5 MM compression rings and a 4 mm oil control rings. Every time I order rings I get ones that are too wide and will not fit in the ring lands. What is the deal I have tried three different places and I keep geting the wrong ones. Do I have the wrong pistons for this motor or are all the parts places in my town full of crap.
Thanks
Anthony
mustang anthony is offline
Old 02-02-2010, 12:47 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
maybe your pistons arent stock? try a machine shop in town see if they have the correct ones in stock
rmodel65 is offline
Old 02-02-2010, 04:41 PM
mustang anthony
I am sure the pistons are stock, the motor is out of a one owner little old lady Town car.
A machine shop is a good idea. if anyone would know it would be them.
Thanks
Old 02-02-2010, 11:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to specify they are metric, I have ordered them through autozone before in the hastings brand
mjr46 is offline
Old 02-03-2010, 09:48 AM
mustang anthony
The problem is Auto Zone doesnt show a listing for standard boar, only oversize. I don't want to boar the block, its like new.
Old 02-03-2010, 10:28 AM
mjr46
mjr46's Avatar
your vatozone is ghey then........lol........hastings part number 4346
mjr46 is offline
Old 02-03-2010, 11:27 PM
Hamutoff
Hamutoff's Avatar
302 Moly ductile iron file fit Speed Pro R10472
Hamutoff is offline
Old 02-03-2010, 11:29 PM
Hamutoff
Hamutoff's Avatar
Bore (in) 4.000 in.
Bore (mm) 101.727mm
Top Ring Included Yes
Top Ring Thickness 1.5mm
Second Ring Included Yes
Second Ring Thickness 1.5mm
Oil Ring Included Yes
Oil Ring Thickness 4.0mm
Oil Ring Tension Standard
File Fit Yes
Gapless No
Top Ring Material Iron
Top Ring Facing Material Plasma-moly
Second Ring Material Iron
Second Ring Facing Material Plasma-moly
Oil Ring Material Chromemoly
Quantity Sold as a set.
Hamutoff is offline
DJ Piner
09-30-2015 03:03 PM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: problem with rings!
