idle problem
Old Feb 7, 2010 | 01:59 PM
foxbod90's Avatar
foxbod90
Default idle problem
the idles moves slowly up and down at idle. the tach doesnt move much but i can hear it outside the car. when i change gears like from park to drive it would bounce a bit for about 10 sec and then correct itself. what could it be? many new parts so i think could be vaccuum leak?
Old Feb 7, 2010 | 03:40 PM
MustangBradley's Avatar
MustangBradley
Vacuum leaks could lead to what you are describing. Pull fault codes from the computer and see if your Idle Air Control valve or your TPS is showing a fault. If you don't have any codes, then a vacuum leak is probably it.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
