T5 Knocking
Old Feb 18, 2010 | 04:37 PM
jagman454's Avatar
jagman454
Default T5 Knocking
Alright I rebuilt this t5 not 5k miles ago.....
When I have the clutch pedal pressed in the knock goes away, when I release it it continues to knock....when it is in gear it knocks.... I have a slow leak and I've always been feeding oil into it, i'm putting dex III into it from advanced auto parts...I dont think i've ever let it get too low on oil but idk.... any ideas?
oh and P.S. my throwout bearing has always made a slight noise when ever the clutch pedal is not pressed in.... the throwout bearing would not knock would it?
thanks for all your wisdom...
Old Feb 18, 2010 | 08:06 PM
Bubba 95SN's Avatar
Bubba 95SN
Pull the transmission take apart. Check input shaft clearances and input bearing. Bubba
Old Feb 18, 2010 | 09:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd also inspect the throwout bearing, putting a load on it can often make noises go away
Old Feb 19, 2010 | 05:18 AM
jagman454's Avatar
jagman454
If its in neutral with the clutch pedal not pressed in it will knock....when I push the clutch in it will also slightly knock.... if I put the car in gear while sitting there it will not knock....
I know I'm going to have to pull the tranny just trying to see what I'm getting into...
thanks guys
jessicarabbit
Sep 25, 2015 12:41 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
degner122
Sep 16, 2015 07:09 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
