91 gt will not restart hot
i have a 91 gt with a 306 5speed it runs great but when you shut it of it will not restat till you let it sit for a hour.it cranks over good but will not start. it has fuel pressure and spark but when you crank it you can smell fuel coming out of the exuast like it flooded. has new 02 senors,tfi module,mass air flow coolant temp sensor,tps. it start great when cold and run all day till you shut it off. has no ac or smog pump or egr a has stock injectors and maf has e303 cam cold air intake anything will help
when it won't start, you need to check for spark and or fuel, inline spark tester and a can of ether will narrow it to a system.......also it'd be handy to have a FP tester to check for leakdown
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
