Nitrous ?
Nitrous ?
Just courious, Would a plate type nitrous kit that is designed to go between upper and lower intake on a 5L , will it also work on the 351 w, even though lower intake abit bigger or no? Any thoughts or opinions welcome thx in advance.
most plate systems are made to fit specific intakes, due to the different runner designs. if you have an aftermarket intake (Holley Systemax, Trick Flow Track Heat, GT-40, etc.) there will be a dedicated plate system for it. if it's for a factory 5.0 HO or truck intake, not much interchanges. all the aftermarket intakes, including the GT-40, use the same upper for the 5.0 and 351...just the lowers are different.
