clutch issues
Old 03-06-2010, 09:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like a cable issue or fork issue, how did the clutch pedal feel when the prob occured??, did it feel like it was moving the clutch fork??? if it felt fine, could still be a shift rail issue in the tranny.....
mjr46 is offline
Old 03-06-2010, 09:56 PM
jssblues
jssblues's Avatar
Clutch felt really tight and was moving the fork but didn't seem to be pulling it out enough like. Something was binding
jssblues is offline
Old 03-06-2010, 10:00 PM
mjr46
mjr46's Avatar
YOUR CABLE IF NOT NEW may be getting ready to snap, often times they become frayed and will catch on the sheath which surrounds the cable
mjr46 is offline
Old 03-06-2010, 10:02 PM
jssblues
jssblues's Avatar
will have to look closer at it tomorrow to make sure heat from headers hasnt affected it but it is almost new
jssblues is offline
Old 03-06-2010, 10:05 PM
jssblues
jssblues's Avatar
actually if i remember right from unhooking it earlier, cable was very smooth as i had to rehook it on the quadrant and it moved very smoothly
jssblues is offline
Old 03-06-2010, 10:12 PM
jssblues
jssblues's Avatar
Could the fork have come off the ball
jssblues is offline
Old 03-06-2010, 10:28 PM
mjr46
mjr46's Avatar
it's possible, with a mirror and light you should be able to shine in there and view it
mjr46 is offline
Old 03-06-2010, 10:32 PM
jssblues
jssblues's Avatar
Thanks for the help mjr. Will update more on this tomorrow
jssblues is offline
Old 03-08-2010, 10:12 AM
mattkoly
mattkoly's Avatar
Check the bearing retainer sleeve, not sure if your year has an aluminum one or not. There is an upgrade to steel which resists wear and hanging of the TOB.
Read this it tells a little about bearing hanging with aluminum retainer:
http://www.latemodelrestoration.com/...aring-Retainer
mattkoly is offline
Old 03-21-2010, 09:44 AM
jssblues
jssblues's Avatar
so how difficult is it to install new bearing retainer??? i have read about having to use endplay shims cause the steel retainer will be different..
jssblues is offline
Quick Reply: clutch issues
