Cam for ported GT40 heads
#31
Wtf i just wanted to know if it can be used with the stock bottem end, i dont have money to get a new short block or get new pistons, Im not even building an engine for a while just wanted to know calm down, ****.. Cant check ptv when im not even doing anything to an engine. I want to see what the best cam is for not doing anything to pistons.
#32
From what I understand the xe276 will work, at least with the 1.6 rockers. The Trick Flow stage 1 will work. Trick flow told me that it would work with 1.6 and 1.7 rockers. The xe270 will work and the 270 Magnum from Comp will work. XE270 seems to be pretty popular cam. Part number for that one is 35-351-8. And of course- the Ford E, F, and B will work. Also Steeda #18 and #19.
#34
here we go again... but i like this cam
http://www.summitracing.com/parts/tf...t=tfs-51402000
and fyi you might want your stock rockers, 1.6 might cause an issue
#35
#36
Adder- you need to chill dude! What part of this don't you get? Nobody wants to buy a cam, spend a weekend tearing a motor down to shortblock, put a cam in, bolt heads back up, just to discover that there may be an issue? Why not talk to some guys who know for SURE what will work and what won't? And before you go on a rant bout always checking PTV clearance on any motor, let's face it- you buy the right cam and put it in motor with facory heads, pistons, etc you wont have to second guess. You start milling heads, milling block, bigger valves, then I get how things will change. By the way, I spoke to a sales rep at Summit and asked about potentially sending a cam back, and he told me no- not after it has been installed. So, can one be sent back? This guy says no!
#37
Let me guess..... pushrods length don't have to be checked and neither should lifters preload. So..... a "install, torque it down and forget it" is the only correct way to do things?...... I think you are the one that needs to face the reality of what are the required procedures to do, so an an engine works for SURE.
#38
just dont tell them you put it in... heh
