HOW MUCH TIMING ON A 100 SHOT
wet or dry kit? stock or aftermarket ignition? how big is the fuel pump? what size injectors?
with a 155 lph pump, MSD 6-AL and a dry kit shooting in front of the mass air meter, I was running 10 deg. timing on a 100 shot...only burnt two plugs in a season.
my zex kit recommends 2 degrees back from the base of 10 for a 100 shot.mine said nozzle between maf and tb.just google brand and instructions and it will pop up. but from what i researched 75-100 is a very safe shot and if you gap plugs properly and run 93 octane you should be good with base timing.i still have snow here but my timing gun and spark plug socket are in the back of the car and going with me on my first few runs!!
It is a wet Nitrous Works kit with throttle body plate, Msd 6A , 255 lph fuel pump , 24lb injectors....
I understand from the factory the EFI 5l come 30* total timing .. is this correct? .. Y car has a Comp Cam 274HR, X303 Alum heads, etc.. So my question is ... From what timing should I start backing the timing down for the nitrous?
if your using 91+ octane and have your stock copper plugs gapped about .042" and it's not hotter than about 75* - 80* you can get away with 12-14* initial timing
when it's cool out, i squirt 80 with 89 octane and 12*
as it warms up i usually knock out timing b4 adding octane
best way is power time it..... start low and work your way up til MPH tails off, keep everything else the same... note temp and air condition
you'll know real soon what you can and can't do just from adjusting it a few times
mph will slow down b4 you hurt anything, and read your plugs
mungodrums
10-07-2015 04:01 AM
10-01-2015 09:11 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
