Help with engine identification
Old 03-15-2010, 10:40 PM
Jmead
Jmead's Avatar
Default Help with engine identification
I just bought a ford 5.0 from a guy on Craigslist. He said he pulled the engine out of his F-150. I got it for $50 with the upper and lower intake, fuel rail, distributor, fuel wiring harness and all of the bolt ons to it. Not bad, but when I got it home in the daylight I noticed a paper tag on it with a wire tie. It said Loveland Auto Salvage and had a small description that it was a 5.0. I think I got screwed, don't care though, $50, as long as the block is good. Finally, my question is, how do I identify what it actually came out of and what year it is so I know how to by the right parts for it? It does have a roller cam and lifters, I can see them because the intake is off. It does not have any casting numbers by the starter though. Thanks to anyone who can help me.
Jmead is offline
Old 03-15-2010, 10:55 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it has casting numbers by the starter, clean the grease off, they are there, trust me
mjr46 is offline
Old 03-16-2010, 06:09 AM
AdderMk2
Banned
AdderMk2's Avatar
if its an old enough block, they might be on the opposite side (drivers) near the oil pan rain
AdderMk2 is offline
Old 03-16-2010, 09:38 PM
Jmead
Jmead's Avatar
Thanks for the quick reply.
The only numbers I see by the starter are 4B26 I even turned the engine upside down to check. The guy told me it came out of a 95 F150. I checked the head number, don't know if it the right number, and found E7TE on it. I think that is a truck head. I tried to Google 4B26 but didn't come up with much. The timing cover number is RF-E7TE-6059-BA. The only thing I found for that was it is a reverse flow but not what years they were made.
Jmead is offline
Old 03-16-2010, 09:45 PM
mjr46
mjr46's Avatar
e7 heads were also on mustangs and trucks
mjr46 is offline
AdderMk2
Banned
AdderMk2's Avatar
are you serious guy???
E7TE...
87 casting
truck
engine part....
/thread
AdderMk2 is offline
Old 03-16-2010, 09:48 PM
mjr46
mjr46's Avatar
nope, still on the passanger side where the starter is.http://www.classicmustang.com/casting_numbers.htm
mjr46 is offline
Old 03-17-2010, 08:16 PM
Jmead
Jmead's Avatar
Thanks guys, I looked at the link that MJR46 posted and the casting is definitely not there. There is no grease on the block that the numbers could be hiding from. The only number by the start was on the flange that sits next to the tranny bell housing, that was the 4B26.
AdderMK2, that sounds about right. I had an 89 Bronco that had the same intake on it that this one does. Just curious so I can help myself, where did you find that info so I know next time. I knew this was a newer motor than a late 60's or 70's block that why asked in the forum and not the classic one.
Jmead is offline
Old 03-17-2010, 08:23 PM
AdderMk2
Banned
AdderMk2's Avatar
ford part numbers are pretty easy to decipher...
heres a good explaination
http://www.classicmustang.com/decoding_part_numbers.htm
AdderMk2 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Help with engine identification
