Breakup at high RPM. Causes?
I have an '86 5.0 & recently it's started breaking up under high load & in higher RPMs at around 50% throttle. Running 92-93 octane fuel on a stock motor w/ bolt-ons. It's fuel injected w/ MAF conversion.
I did an oil change & today I changed the fuel filter. Filter seemed to help a little, but it's still breaking up. I got a new set of plugs but didn't put them in yet.
I pulled one of the plugs & they were a little white, so I'm guessing it was running a little lean.
Aside from the plugs & fuel filter what else could be causing it to break up under load? It's not bogging like it would if it were rich, but seems to be running out of fuel or the ignition is breaking up.
Thanks,
-Nick
Thanks,
-Nick
about a 100 different things cap, rotor, wires, dirty maf, weak pump, restriction in fuel sysytem, fuel management issues........ect ect...run a koer test and look for codes first
I don't have a fuel pressure gauge. Nothing has changed on the car & it just started breaking up.
I'm going to do the plugs tomorrow & if that doesn't do it I'll head to Autozone & see if they can pull any codes & I'll pick up a can of carb cleaner & clean off the MAF sensor.
If that isn't it I'll go with a new cap/rotor & plugs. Is it worth going with an MSD ignition on a 5.0 with just bolt-ons?
autozone won't help you on an obd 1 koer test for a ford, I doubt anyone there will even know how to run the test or much less even have the tool to do it....google DIY KOER and you can do it at home
lol. They'll just have to get over it. My single cam coupe went 13.7@105 on a homemade turbo setup that was put together for less than $1k. :P
Thanks,
-Nick
Thanks,
-Nick
my first inspection point, aside from running codes, would be distributor shaft bearings.
a wobbly rotor does no good for spark conduction.
if you check everything else and cant find it, yank the dizzy and see if you have play in the shaft. if your dizzy is stock, its a good bet they're at least "more looser" than they were in 1986. i'll almost guarantee you have spark issues somewhere along the line... if you had fuel issues it wouldn't be misfiring throughout the higher RPM's, it simply wouldn't reach the higher RPMs.
