Can't rev past 3k
Old 08-01-2005, 10:27 PM
  #21
wildstang87
wildstang87's Avatar
Default RE: Can't rev past 3k
ah ha, thats what i needed to know, the maf is most likely the culprit. it sounds like its not responding to the change in air charge velocity. still get the codes pulled, but youre probably going to get a lean condition code which wont tell you much, but its worth a try. after the codes are pulled you can unplug the maf and drive it, see how it reacts, it wont be 100% with it unplugged, but you will definately know if thats the problem, which im pretty sure now it is.
wildstang87 is offline
Old 08-02-2005, 05:56 AM
  #22
punishercb
punishercb's Avatar
Alright, I'll give 'er a shot. I can't scan my code either now because my port isn't working with the scanner.(things just go from bad to worse)
punishercb is offline
Old 08-03-2005, 01:42 AM
  #23
Quik
Quik's Avatar
if it revs fine without a load then stumbles with a load it could b the cats
Quik is offline
Old 08-03-2005, 10:52 AM
  #24
wildstang87
plug wires will also cause the same thing, but i would still have the codes pulled by someone that knows how (not autozone) instead of blowing money on somthing that isnt bad.
Old 08-03-2005, 12:21 PM
  #25
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
ORIGINAL: Quik
That sounds more like plug wires than the cats being clogged. You didn't say it reved fine when it wasn't under load.
Sidewayz6.0 is offline
Old 08-08-2005, 07:20 PM
  #26
punishercb
punishercb's Avatar
Ok all, I've been on vacation but I found the problem. It was my MAF. I cleaned it with alcohol and a tissue and now it works great. Thanks for the help all!!
Old 08-09-2005, 12:09 AM
  #27
obryantbbf
obryantbbf's Avatar
check your Idle Air Control Valve dude, might to replace
obryantbbf is offline
Old 08-09-2005, 03:27 AM
  #28
Quik
Quik's Avatar
well when a car under load it will create more heat. with more heat will cause a bad cat to heat up more and cause melting of the ceramic of the insides. when it melts it then cloggs the air flow. with this it then causes massive amounts of backpressure. so much to the point it can stall out the motor.
but if yorue just free reving its not under load so heat isnt as great and air flow will still pass thru the cats. unless the cats are totally shot
plug wires are just a miss and you would see it thru out the rpm range with or without a load. butwith a load you would more likely see it being worse.
but in his case it was his maf being dirty
ORIGINAL: Sidewayz6.0
ORIGINAL: Quik
Quik is offline
cr620
10-03-2022 10:18 PM
firehorse02
11-16-2015 11:28 AM
88 orangepeel notch
10-05-2015 09:03 AM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Can't rev past 3k
