new clutch
RE: new clutch
I would replace these parts when doing a clutch change:
rear main seal
pilot bearing
throwout bearing
grease the clutch fork ball joint
put syntheic ATF in the tranny
grease the joints in the driveshaft
resurface the flywheel
rear main seal
pilot bearing
throwout bearing
RE: new clutch
get a good quadulant, inspect the slave cylinder, resurface the flywheel, i think for your tranny you want to use dextronmercon III ATF. not just any ATF. a new tranny mount if needed
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
