Help on oil level question
Old Apr 22, 2010 | 03:16 PM
Mustang1994's Avatar
Mustang1994
Default Help on oil level question
I checked my oil prior to my oil change and when I drained it it seemed it was really low after drain. And when I added the oil and let it sit, I checked my dip stick and the stick showed it had double the oil in it, how is this possible when I drained it and now shows way full. I don't want it to over pressurize the engine.
Old Apr 22, 2010 | 03:23 PM
mattdel's Avatar
mattdel
you only did the front drain plug. there's 2. the rear sump holds much more oil.
Old Apr 22, 2010 | 04:54 PM
Jfsram's Avatar
Jfsram
May be it's the way you check it.
I check on a warm engine that's been off for a few minutes.
Wipe stick, reinsert and pull it out for a look.
Old Apr 22, 2010 | 09:07 PM
Bubba 95SN's Avatar
Bubba 95SN
Two drain plugs.
Old Apr 23, 2010 | 04:02 AM
street4130's Avatar
street4130
+1 . i also did this the first time i changed the oil after buying my mustang. i still dont know why there needs to be 2 plugs , but there are lol
Old Apr 23, 2010 | 07:15 AM
AdderMk2's Avatar
AdderMk2
Banned
if you actually bothered to THINK about it. the subframe runs directly through the oil pan location, splitting it in half. the only way to get ALL of the oil out, is to pull both plugs.
that little thing called gravity... it keeps the oil from going OVER the hump for the subframe, and draining out the other drainplug
*facepalm*
Old Apr 23, 2010 | 09:14 PM
Bubba 95SN's Avatar
Bubba 95SN
No such thing as gravity. The Earth sucks.
Old Apr 24, 2010 | 03:53 AM
joshs89gt's Avatar
joshs89gt
*facepalm*
oooooooooooooooooooohhhhhhhhhhhhhhhhhhhhh wow ! that explains EVERYTHING !
04stangman
Sep 17, 2015 01:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
kevsgt
Sep 9, 2015 06:20 AM
Sep 8, 2015 11:50 AM
