T5 Getting into gear
Old May 10, 2010 | 08:44 PM
speemike's Avatar
speemike
Default T5 Getting into gear
I am having problems getting my T5 into gear. It is really hard to get the car into reverse or first even when it is not running. Sometimes I need to grab the shifter with two hands and go into 5th and then slam it into reverse, same with first gear. Once I get it into reverse I can go back and forth from 5th to reverse and its really smooth. I just replaced the clutch and it seems to be working fine. I just got the T5 from someone else so I do not know if it had this problem before the new clutch. I have adjusted the clutch in both directions and it hasnt made a difference. I do not have any kind of grinding when shifting. Any ideas?
Old May 10, 2010 | 09:19 PM
stang8689's Avatar
stang8689
sounds like synchros in your tranny
Old May 11, 2010 | 12:32 AM
mattdel's Avatar
mattdel
el junko.
Time for a rebuild. Luckily T5 transmissions are a dime a dozen. Yank it yourself and bring it to a trans shop. Should be dirt cheap.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
