if you are talking EFI, the lowers will not interchange, but the uppers will. so if you are doing a 351 swap keeping EFI, retain the 351 lower and install the 302 upper
No. The 351 uses a wider intake manifold. The only exception noted is the 2 piece EFI intakes, where the upper is the same, but the lower is different.
