Timing numbers/scale is to worn down on harmonic balancer
Old 07-19-2010, 09:54 PM
centipede3001
centipede3001's Avatar
Question Timing numbers/scale is to worn down on harmonic balancer
The timing numbers and scale is really worn down on my harmonic balancer and impossible to rear what can i do ?
centipede3001 is offline
Old 07-19-2010, 10:01 PM
KingKobra
KingKobra's Avatar
compare to another balancer and create your own marks if possible
if not sounds like you might have to replace the balancer if its causing you serious problems
KingKobra is offline
Old 07-19-2010, 10:44 PM
Jfsram
Jfsram's Avatar
Use a dial back light.
Jfsram is offline
Old 07-19-2010, 11:23 PM
centipede3001
what is a dial back light ?
Old 07-20-2010, 12:16 AM
pkrpro
pkrpro's Avatar
Find tdc, (if u dont know how the old fashond way.. they sell a little tool with instructions) install a timing tape. Bingo your problem is solved.
pkrpro is offline
Old 07-22-2010, 10:19 AM
Jfsram
Jfsram's Avatar
A basic timing light just flashes the same time you get spark. So the number you see next to your pointer is your ignition timing. So if see 10 deg next to your pointer, it's 10 deg.
A dial back light has a dial or display. If you set the display to 10 deg. Electronically the flash is delayed 10 deg. So now the light will flash 10 deg out of phase. So you will see TDC, which is Zero and well marked on most engines, lined up with the pointer.
Another situation would be to want 15 deg. So you set the dial back light to 15. Run the engine and adjust the distributor until the zero lines up with TDC.
Jfsram is offline
Old 07-22-2010, 05:35 PM
mattkoly
mattkoly's Avatar
This works if you know where the TDC number is, i had to do it with the special tool referenced earlier.
mattkoly is offline
Old 07-25-2010, 02:15 PM
centipede3001
I tried using a vacum meter to set it and i think i got it pretty close cuase its not pinging and its running a lot better hopefully my new fuel pump will fix the rest of the problem
Old 07-26-2010, 12:27 PM
pkrpro
pkrpro's Avatar
Are u not able to read? Do it the correct way.
pkrpro is offline
Old 07-29-2010, 08:40 AM
Jfsram
Jfsram's Avatar
Zero is marked with a huge notch.
Jfsram is offline
Quick Reply: Timing numbers/scale is to worn down on harmonic balancer
