runnin rich ???
#22
i jus double checked firin order today to make sure was all right n it is .... and also for u guys i forgot all bout this till drove it tonight i havent drove n while but when turnin left it falls on its face like acts like runnin out of gas and sometimes dies and have to start back up ...
#24
ok well i tested few cylinders today and im hopin like hell my the tester i was using was junk or maybe was right idk ...i dont num 1 and i unhooked coil and jus cranked motor and would raise up to 60 and back to 0 on compression then i started the motor and 00000000 lol so i went to driver side and dont 5 and 6 and they were the same . the compression tester had was a old school one threaded into heads .... but does this sound bout right on compression ?
#26
what mean ? im not certified mechanic by no means lol ... but know fair share bout things . but i jus pulled 1 plug out at a time n checked em that way . check and put plug back in and move to next .
#27
DON'T be offended, take a little more time typing so its easier to understand. From what i could follow in your post, no that doesn't sound right, the compression tester should've been pushed to a certian psi and held there on its own (unless you're pressing the release button).
Prop open the throttle plate
screw in compression tester
turn the motor over (you unhooked the coil wire, right?) around four times
If your guage isn't like the one I have that holds its place you may need a friend
#29
well i got bored tonight n said hell with it . im pullin motor and trans both out cuz trans is a aod and it slips bad n 1rst . so i got another trans with shift kit and 2000 stall . but main reason tearin all out is cuz my strut towers are rusted ... but on way tearing it apart i did find out why my car sounded like was suckin air. my plenum on back bolt was busted . so yay for me i guess now time to look for a gt40 upper n lower . but also while is out im gonna change all gaskets and maybe bearings and oil pump . any body know good site get go deals on gasket kits n everything else ?
#30
to have good readings you want to make sure your engine is warm. Remove all spark plugs and every cylinder. disable the fuel system and you can either have the throttle stuck open or manually by foot with the pedal. make sure you crank the engine three times. you should get a good reading that way.
