New axles??
New axles??
So i just ran into a curb pretty hard fishtailin my 94 and cracked the rim and bent the axle.....got the axle out now im debating to go with stock or get a set of mosers..what do u think?? also should i replace the seals and bearings while theyre out or will they be good?
RE: New axles??
i'd put in sum mosers while you have it all apart so you got sum strength in there, i think i might have bent my axle too i was racing on a **** highway from a dead stop it was spinnning then hit 5000 rpm n wheel hopped really bad to 6000 rpm then when i hit second it wheel hopped a bit n then i stopped because the other guy blew a gear(my buddy) n heard this weird clunking n clinking noise, wasnt sure what it was but it only makes it when i go over bumps sumtimes. got any ideas?
RE: New axles??
honestly i wouldnt upgrade its a waste of money. unless you plan on going to 31 spline. if you already have 31 spline then upgrade but if your stock with 28 spline then i wouldnt and just put a stock on back in. chances are your not that powerfull yet to snap an axle or shear off the lugs or hub
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
