1994 Cobra VS. GT performance differnces
ORIGINAL: af41
COBRA INTAKE, IRON GT40 HEADS, 24# INJECTORS, 65 MM TB(I THINK)
215HP(GT)
240HP(COBRA)
SOME SAY COBRA UNDERRATED AND IS MORE LIKE 270HP
215HP(GT)
240HP(COBRA)
Engine:
Cast iron GT40 heads
Cast aluminum Cobra intake manifold (according to flowcharts, outflow's GT40)
Crane 1.7 rocker arms
24lb fuel injectors
Cobra specific ECU (computer)
"Cobra" stamped valve covers with build sticker and signature
3.08 rear gear
Engine oil cooler
Front mounted power steering fluid cooler
Lightened flywheel
Phosphate coated transmission gears
Overdriven waterpump pulley
Cobra specific camshaft
Cam specs: Duration: 227°/Intake & 270°/Exhaust
Lift: .485/.485 Intake/Exhaust
Lobe separation: 118.5°
Suspension/Brakes:
13" Front brakes
11.65" rear brakes
"Cobra" embossed front calipers
Cobra specific brake booster
Cobra specific rear sway bar
Cobra specific shocks/struts/springs
K-member that is slightly stiffer than the GT's
No strut tower brace
Interior:
Steering wheel center / Airbag cover embossed with "Cobra"
White faced gauges
160mph speedometer
"Cobra" embroidered floor mats
Exterior:
Cobra specific 17" wheels
Cobra specific rear spoiler with integrated 3rd brake light
Cobra specific front bumper cover
SVT emblem on decklid (95-up, not on 94)
Cobra emblems on front fenders (no 5.0L emblems)
"Crystal" (clear) headlights
Round cobra specific foglights
Other info:
The 94-95 Cobra (and GT) came with a 60mm throttlebody, not the 65mm alot of people believe it to have. The 93 cobras came with a 65mm.
Although the 94-95 Cobra came with 24lb injectors it still uses the same MAF (mass airflow meter) as the GT. The Cobra specific computer compensates for the 24lb injectors.
Many people say the Cobra came with underdriven pulleys but from what i've heard it only has a Cobra specific overdriven waterpump pulley. Even if they are slightly underdriven they are nowhere near the same as real underdrive pulleys.
94-95 Cobra trivia information (posted on the SCOA bulletin board posted by "Dano" from the SVT cobra recognition guide)
1. '94 was the first year of the front facing Cobra snakes!
2. These two years were the only ones to have the "Crab Claw" spoiler, with built-in LED brake light! (The GT's stop lamp was mounted on the rear decklid)
3. Only three colors were offered:
a. Rio Red Tinted Clearcoat
b. Crystal White
c. Black Clearcoat
4. The '94 Indianapolis 500's official pace cars were GT's converted to Cobra specifications.! They were five converts, with a four-speed AOD automatic trans! The actual "Pace Car" was driven by Parnelli Jones. 1,000 of these replicas were built, for sale to the public! If you have a '94 convert, it's an Indy 500 replica, with all the special badges & markings, and it's red!
5. The easiest way to tell a '94 from a '95:
a. The '95 has an SVT badge on the trunk lid.
b. The '95 has a vertical flair attached to the front of the rocker panel extension.
6. ALL '94 Cobra converts were Rio Red Indy Pace Car replicas.
7. ALL '95 converts were black.
8. The '94 convert tops were saddle color, and the '95 convert tops were black. No other color combinations were available!
9. '94 and '95's converts came with saddle interior.
Awesome, thanks alot for the breakdown. Off hand you wouldn't happen to know, or have maybe heard, the cheapest way to boost performance in general on our Cobras (whether it be drivetrain, motor, fuel system) in terms of best bang for the buck have you?
ORIGINAL: cobrazilla
I seriously doubt they are under rated.
you think between a bigger TB, better flowing intake, GT40 heads, healthier cam and 1.7 rockers, cobra ECU they only got 15hp? yeahhhhh
Gears. from what everyone says. and thats my next thing hopfuly within the month.
nice car too.
nice car too.
ORIGINAL: seight311
ORIGINAL: OnyxCobra
well i doubt they werent
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
1994, 2004, 94, 95, aftermarket, cobra, cooler, difference, gt, heads, mustang, oil, performance, tb, vs
