Turn signal flasher location for 90 LX
Thanks for the diagram. It's actually one that was sent to me by dreamer1uk. But did go over it and still nothing. Tried 3 different working multiswitches and nothing. Tried a new hazard switch and nothing. I'm a bit lost now =/
But. I did find a inertia switch mounted to the rear of my car, in the hatch area, where the tail lights mount. What is this for?
Hey I found this cluster wiring diagram. Would it be smart to get a test light and see if it's putting out anything to the indicators?
http://www.stangnet.com/tech/cluster87-93.pdf
even though if you said your flashers work so its getting power, its when the relay is powered that would be useful, if the turns work when you use the flashers but not the turn signals that would point more towards your actual turn signal switch being bad.
I didnt think the fox bodies had relays? Even the wiring diagrams i have do not point to any relays. There are flashers for the hazards and turn signals but they are completely different from relays
Check your ignition switch in your steering column. Pry sounds retard but I had the same issue for awhile and i found my ignition switch was loose,and that was the problem. I dunno if the turn signals get power from there or what but....check it out.
jwog666
12-27-2021 08:09 PM
09-27-2015 03:16 PM
logan409
09-26-2015 07:43 PM
