1995 SVT Cobra 5.0 cam position sensor
Old Feb 21, 2011 | 08:39 PM
SuthernThunder25's Avatar
SuthernThunder25
Default 1995 SVT Cobra 5.0 cam position sensor
I own a 1995 SVT Cobra 5.0L. I am having a hard time researching about the Cam Position Sensor. I was wondering where it might be located on the car. Ive had several people tell me different answers.
Old Feb 21, 2011 | 09:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
doesn't have one, it has a stator/hall effect sensor in the dizzy that Id's tdc
Old Feb 21, 2011 | 09:35 PM
Venomantidote95's Avatar
Venomantidote95
+1 thats the only correct one!
Old Feb 22, 2011 | 07:20 PM
Bubba 95SN's Avatar
Bubba 95SN
Going to be most difficult finding that part on a 95.
Old Feb 22, 2011 | 10:49 PM
mgmuscari's Avatar
mgmuscari
Wait a second, is that a regular TFI dizzy or is does it provide cylinder 1 ID as well??
Old Feb 22, 2011 | 11:47 PM
AdderMk2's Avatar
AdderMk2
Banned
AFAIK, its a TDC signal only. I didnt inspect the reluctor wheel when I had mine apart, to verify the spacing between all the teeth.
Old Jul 29, 2012 | 05:22 PM
Xsentric's Avatar
Xsentric
im having the same issue in my 95 5.0 gets to running temp and dies. i noticed the stator looks like a few teeth had scraps like was rubbing also pick up had a magnetic pull with battery disconected of course.. is that bad?
Old Jul 30, 2012 | 09:24 PM
mjr46's Avatar
mjr46
pull the distributor and make sure the bushing is not worn out that houses the shaft
Old Aug 15, 2012 | 09:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
different plug from a fox and the TFI is mounted on the apron to try to solve the heat problems of it mounted on the dizzy
Nov 10, 2015 11:39 AM
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Sparks_88
Sep 8, 2015 01:06 PM
vintageaion
Sep 8, 2015 10:45 AM
