Codes need help
here we goo I pulled all the codes out of my new 89' stang.
Koeo
11-system pass
Continues Memory:
33-EGR not opening
41-Hego sensor indicateds system running lean (right side)
66-Maf sensor went below .4 volts during last 80 warm up cycles
91 no Hego switching dected always Lean(left side)
KOER:
21-ect out of self test range
41-No hego switching detected running lean (right side)
91-hego sensor cuircuit indicated system lean (left side)
33-EGR not opening
anyone help me fix it from running lean.an it not seeing the maf in warm up cycle...help me fix my car
Koeo
11-system pass
Continues Memory:
33-EGR not opening
KOER:
33-EGR not opening
Hego is your O2 sensor. Prolly means you need 2 new ones. Sounds like your MAF is grounding out, same thing happened to me, go buy a remanufactured unit. For the EGR, try buying one of those EGR delete sensors so the computer thinks it's opening and closing.
lincolnshibuya
Dec 8, 2015 04:37 PM
