sway bar links
Old 08-03-2011, 06:36 AM
1988TTOP
1988TTOP's Avatar
Default sway bar links
so i went to pull my old rack out today and noticed the brand new sway bar links i put are bent. what in the hell would cause this
1988TTOP is offline
Old 08-03-2011, 12:41 PM
tohoopty
tohoopty's Avatar
what kind of end links did you buy.did you tighten them up with the car at ride height or did you tighten them up with the wheels at full droop
tohoopty is offline
Old 08-03-2011, 03:24 PM
1988TTOP
1988TTOP's Avatar
i bought the energy ones i tighten them up with the car on the ground
1988TTOP is offline
Old 08-03-2011, 09:49 PM
Jfsram
Jfsram's Avatar
The original design of the sway bar system forces the lower end of the link to travel in an arc. Polyurethane bushings do not compress all that much. So they force the long bolt to bend.
Jfsram is offline
Old 08-03-2011, 10:01 PM
tohoopty
tohoopty's Avatar
ive had energy suspension end links on my car for 2 years and havent had a bit of problem with them.car also sees full range of suspension travel too
tohoopty is offline
Old 08-04-2011, 06:21 AM
1988TTOP
1988TTOP's Avatar
so any ideas on way they bent i would hate to go buy new ones and they bend again
1988TTOP is offline
Old 08-05-2011, 11:48 PM
Jfsram
Jfsram's Avatar
Try not to tighten them until the bottom out on the sleeve.
This will compress them a tiny bit less, allowing for some misalignment.
Or go back to the factory rubber set up. Neither is good advice when handling is the priority but it will put a little less stress on the long bolt.
Jfsram is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
Quick Reply: sway bar links
