Brake issues!
Brake issues!
I have a 94 Gt that has upgraded brakes off a 99-04 model. When i got the car the front brakes were a little hung up but i thought no big deal the slide pins need cleaned up and regreased. Well yesterday i took it all apart and greased them and took it for a ride and sure enough it didnt fix my problem. Clearly the pistons arent going all the way back in as i found when i took it all apart. Anyone have any ideas? I cant imagine both calipers being bad at the same time? Thanks for any reply
Calipers not releasing is one of two things:
1: Caliper is freezing
2: Rubber hose attached to caliper is collapsing under pressure, locking pressure into the piston. Nearly impossible to see by eye.
On the more extreme side, you could have a malfunction in the master cylinder, but more obvious symptoms would be present in most cases.
Given that you've done the brake swap, however, something could be wrong in the prop(diverter) valve, causing it to act like a line lock.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
