charging problems??
Old Nov 23, 2011 | 06:02 PM
latinmustang90's Avatar
latinmustang90
Default charging problems??
I recently replaced the battery and took the alternator to have it tested and is working normal I check my grounds and my connections look ok .... I also noticed my battery light in the dash is not working either when I open the ignition switch stays off what could be wrong any hints please help.....sos!
Old Nov 23, 2011 | 06:15 PM
Bubba 95SN's Avatar
Bubba 95SN
Fusible link or posible the ignition switch.
Old Nov 23, 2011 | 07:00 PM
latinmustang90
the car starts normaly when I jump cables and stays on till it drain the battery out... the only problem is that is not charging everything works like lights, interior lights, power locks, wipers, etc .... the ignition switch is brand new could a fuse link be the cause of the charging issue??
Old Nov 24, 2011 | 08:01 PM
Bubba 95SN's Avatar
Bubba 95SN
veryuseful.com will show what you need.
Old Nov 24, 2011 | 08:26 PM
latinmustang90
is Fix bro thanks for your help all it was is the little circuit board behind the cluster is kind of old is tear in one end thats why I had the charging circuit open but now is working well thanks appreciate
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
