AOD shifter cable replacement
I have tried adjusting my cable but it is either stretched or broken somewhere. It will NOT go into 1 and park its either or. I really can't afford $80 for a new replacement which leads me to look at aftermarket cables. Has anyone used a universal cable with any luck from summit or somewhere else?
I understand, I'm just curious if any of the B@m or hurst cables would work on the fox body. They are a better cable, have better connections on the end and are half the price. I want to order a B@m cable with a loop/threaded end and attach the hoop to the AOD and use an adjustable ball socket on the threaded end for the shifter mount.
Thanks for the info 4drnut. I have tried leaving it in OD and adjusting the slack in the slide nut both ways with no luck. I will try it in N and if that doesn't work I guess I will have to buy a new oem cable.
