driveshaft rubs?
Old 12-29-2011, 06:40 PM
Js88lx
Js88lx's Avatar
Default driveshaft rubs?
well i noticed that my driveshaft keeps kissing the tranny hump only when i have passengers in car..? What gives??
Js88lx is offline
Old 12-29-2011, 06:50 PM
99GTvert
is my username.
99GTvert's Avatar
Stock driveshaft? 5 speed?
99GTvert is offline
Old 12-29-2011, 07:15 PM
Js88lx
Js88lx's Avatar
im not sure, i bought car as is. Can that be problem? Car looks like an original 5spd but can be wrong.! Anyway to figure it out?
Js88lx is offline
Old 12-29-2011, 07:22 PM
99GTvert
is my username.
99GTvert's Avatar
I'm sure both units have a number/figure stamped on them that would help determine if they are standard OEM stuff or aftermarket but if you are going to get under the car to look it would also help to have a gameplan too.
I'm not really sure what the problem could be but if it happens only when you have people in the car maybe it could be suspension related. Is the car lowered? Are suspension components like the shocks/struts, control arm bushings etc. in good condition?
99GTvert is offline
Old 12-29-2011, 07:25 PM
Js88lx
Js88lx's Avatar
sorry my bad..., yes iis a stock driveshaft!!
Js88lx is offline
Old 12-29-2011, 07:28 PM
Bubba 95SN
Bubba 95SN's Avatar
Ahh, how big are your passengers? Does the ride height unloaded look comparable to same year car? Thinking the lowering springs may be installed. Bad wrong transmission mount.
Bubba 95SN is offline
Old 12-29-2011, 07:46 PM
Js88lx
Js88lx's Avatar
salvaged car due to front end damage on drivers side! Car is lowered only from the front, but cant see that being the problem since i still need back lowered, kinda how car lowers when people are in car so if i was to lower it from the back wouldnt it hit more..., thats what im thinking..!!
Js88lx is offline
Old 12-29-2011, 07:51 PM
Js88lx
Js88lx's Avatar
No fat asses, no offense....lol. Im leaning twordes the tranny mount along there as the problem!!
Js88lx is offline
Old 12-30-2011, 07:19 AM
Tony71502
Tony71502's Avatar
Only a wrong tranny crossmember / hugely oversized tranny bushing would do that. But even still... a lot of people, including myself, run aluminum driveshafts which have a larger diameter than the stock steel driveshafts and do not have this issue. Something else is at work here, I think.
Is your floor dented/bashed up? Are you sure a shoddy exhaust isn't hitting the driveshaft? How do you KNOW that when the car is loaded with passengers(and I'm guessing you're not underneath to see, at this point) that the driveshaft is the problem? Can you see wear marks on the driveshaft where it is rubbing?
Tony71502 is offline
Old 12-30-2011, 09:23 AM
enix187
enix187's Avatar
the Parking brake bracket can come loose and allow it and the cables to run, does you parking brake handle lock in a really high position
enix187 is offline
Quick Reply: driveshaft rubs?
