cluster needle issue
Old Jan 22, 2012 | 08:04 PM
javila2468's Avatar
javila2468
Default cluster needle issue
I pullled the cluster off the replace the black faceplate with a white face plate. When reinstalling everything back the needles are not showing the correct water temp, rpm, gas lvel, oil pressure, voltage and speed. Does it have to be recalibrated?
Old Jan 22, 2012 | 09:42 PM
mattdel's Avatar
mattdel
If you call removing the needles and fixing their locations calibration.
Old Jan 22, 2012 | 10:01 PM
javila2468's Avatar
javila2468
Yea...i removed the all the needle so that i can replace the face plate. So, would they need to be recalibrated? Or would reset on their own after a while?
Old Jan 22, 2012 | 11:10 PM
javila2468's Avatar
javila2468
IISSUE SOLVED!!!! had to recalibrate each needle individually.
Old Jan 23, 2012 | 11:32 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
next time you'll learn and mark the position they were in before pulling them/something apart
Old Jan 23, 2012 | 04:08 PM
ttocs's Avatar
ttocs
just take a pic of them with the car warmed up and running, return them to that spot when you are done.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
