Installing speedo gear on 94 5.0.....
RE: Installing speedo gear on 94 5.0.....
p diddy ,
so you saying when you changed your stock gear to a 3.73 . at an actual speed of 65mph ,you speedo was ready 90 ?
I just swapped my stock 3.08 to 3.73 . For some reason, i thought that going with bigger gear will reduce the speedometer reading . more like reading 50mph at an actual speed of 65.
any input ?
any input ?
if it's a t-5..get under car follow the cable to the driver side before the taleshaft,,,,pull off the lil clip on the plastic piece..I believe it's a 10mm socket to remove the bolt and then pull it out..,when you see the gear remove the clip holding it in and reverse to install, make sure you have the right gear for your trans..takes about 10-20 mins...you may have to move the gear some for it to fall into place
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
kawiguy827
09-01-2015 07:09 PM
