94 mustang gt auto????
ive got a 94 mustang gt conv automatic and i wanted to change it to a manual is there anything you guys can think of that i need to get other than
the
-transmission
-clutch
-flywheel
-driveshaft
-clutch and brake pedal assembly
-shifter
thats all i could think of that i would need to buy and does anyone know if i will need an adapter to bolt the manual trans flywheel to the crank?
thank you for your time and help
the
-transmission
-clutch
-flywheel
-driveshaft
-shifter
I am probably going to do the same thing and, as far as I know, this is what is needed:
T-5 transmission
Clutch fork
release bearing
pilot bearing
clutch kit
flywheel
5 speed manual clutch and brake pedal assembly
dust cover/block plate
stock shifter
drive shaft
5 speed ECU
transmission wiring harness
5 speed manual cross member
clutch cable
SHIFT BOOT
all the bolts and fasteners you need
I hope that this helps. I'm going to buy up parts over the winter and do the conversion next Spring/Summer. I'll probably go with a TKO600 for the trans, so it can handle additional engine upgrades.
T-5 transmission
Clutch fork
release bearing
pilot bearing
clutch kit
flywheel
stock shifter
drive shaft
5 speed ECU
clutch cable
SHIFT BOOT
ShaneB26154
35
03-04-2021 04:05 AM
raven_ghostwolf
08-16-2015 08:16 PM
