hard to start
hard to start
It takes alot of pumping the gas and trying one twice three times to get it to crank ovr. Then it starts out real low idle then slowly raises in idle untill its idling normal. Has new ford racing plug wires. Autolite plugs. Msd cap n rotor. Msd blaster coil but stock duraspark ignition box. When i turn key i dont hear fuel pump enguage. But wile running and driving i uear a hiss or ppppssssssshhhhhhhttt noise when driving. It goes away when i apply breaks. Was told its hard starting hc the master cyl should b replaced? Help please i want to get this thing going again....
im 99% certain its a vac leak as well
vac leaks will cause basically EVERY drivability problem out there, and they wreak havok on the 5.0 EFI
fix all of them (there will be more than 1...trust me) then come back and repost whats up
He has a carb. But a vacuum leak will still wreak havoc with starting.
Your carb pulls fuel from the bowl using vacuum , a leak in the system when the car is cold especially will starve the engine of fuel .
Try to plug off the vacuum line going into the brake booster and see if it helps the starting.
if it has a internal vacuum leak yes you would need to replace it.
First though I would make sure that's what is causing the problem by unhooking the vacuum line from it and plugging the line. If it starts up better you found your problem
Dragonus18
09-09-2015 01:21 AM
