Suspension compatibility
As far as I knew suspension was interchangeable from 79-04. I need shocks and springs BAD for my 94, I found a cheap kit but it says 87-93. Now I'm fairly confident it should work I just want to double check.
Yeah, I remember the control arm difference. I was shopping for shocks/struts and springs. I had heard something about the springs rates on the foxes being softer but I figure aftermarket springs for a fox would be at least the same as sn-95 factory. What I ended up getting was sr springs and gr2's. Also got prothane bushings for the front end. Hopefully it all comes in by Wednesday morning so I can have it all installed and ready for my alignment/exhaust appointment Thursday.
I was mostly unsure of the shocks/struts, I thought they were the same 79-04 but the different generations called for different part numbers for the same model struts so I ended up taking the safe road and spending a bit more cash :-/
Matt's 95 Stang
Oct 5, 2015 07:16 AM
junior04
Sep 28, 2015 10:53 AM
