mustang having problems
Old Mar 3, 2013 | 07:07 PM
Fordfoxbody88's Avatar
Fordfoxbody88
Default mustang having problems
i have a 1992 mustang that use to be a 4cyl but is now a v8. i have now made it fuel injected, i got a wiring harness out of a 93 gt along with intake. now i have it running but when it idles it lik surges between 750- 500 rpm and when i drive i if im jus cruising once i get the motor under a little bit of a load and the motors at lik 1500 rpm it starts surging and it just doesnt seem right, now i ran some codes on it and these are what came up 67,81,82,85,84 ive already put a new mass airflow sensor on it along with to new o2 sensors and a throttle position sensor and a idle valve assembly thing ive checked all the vacuum lines and have most capped off and others hooked up if i know they need it. i thought it was the egr so i made a plate to delete it today and it didnt help at all it may have actualy made it a lil worse so i think im going to put it back on. i dont know if theres something i could have forgotten or if a sensor is bad or a injector could be messing up or if it could jus be timing. it starts just fine and runs great if ur on the gas or even jus above 1500 but it seems lik once u get below that it starts surging and staying steady. please help im at my witts end and tired of throwing money at it.
Old Mar 3, 2013 | 08:35 PM
Bubba 95SN's Avatar
Bubba 95SN
Go to Joel 5.0 and follow the test proceedures. Ck fuel press.Do all 3 cyl bal tests. Post results.
Old Mar 3, 2013 | 08:45 PM
Fordfoxbody88
fuel pressure is fine brand new pump lines and all
Old Mar 5, 2013 | 08:48 AM
BabyGT's Avatar
BabyGT
Doesn't mean you didn't get a defective pump or something. It's free t rule that out before you dump money into it to find out its a factory messed up part. It happens.
Old Mar 5, 2013 | 02:21 PM
fox bodies rule's Avatar
fox bodies rule
did youi put a FP gauge on it and check or are you assuming that a new pump=good pressure? I had the small hose from the pick up to the pump body come loose and it was enough to cause your symptoms. The Joel checklist is a fantastic trouble shooting tool as noted in another post.
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
daytooday
Aug 11, 2015 09:22 AM
philster0306
Aug 10, 2015 11:33 AM
