how to launch?what 1/4 and 60
i have a 347 with forged pistions.TFS Heads,2.02 intake 1.60 exhaust.with edelbrock upper and lower.1.6 rockers.pullies,mac cold air intake.2 chamber flow masters,with mac h-pipe.190ilp in tank pump,also a inline t rex pump.73mm mass air.65mm throttle body.24ilb injectors.150 sht nos kit.mac headers.i have a set of slicks but there kind old.26/50/15 are the size.what 60ft should i have and what 1/4 time.also how should i launch it? also have a 3.73 gear with a 5 speed <SPAN class=smText>
</SPAN>
</SPAN>
run with 18psi in the tires. launched at 3Gs. if you had a suspension i would say higher but this should be good for you. as far as your time. that is up to how you drive. with that setup and if its tuned right. you should be in the 11s at least. there is some dude up here with a 347 holley intake setup. and a150 shot running high 10s low 11s.
good luck
good luck
347 and sprayed..do you know what kind of horsepower number your getting out of your motor without juice??what you have done to your motor if pretty much exactly what i want to do to mine over the winter</P>
Daddys Girls GTs
09-14-2015 08:46 PM
