how do i convert e-street heads from stud mount to shaft mount?
Old 07-01-2013, 11:04 AM
DrGibs347
DrGibs347's Avatar
Default how do i convert e-street heads from stud mount to shaft mount?
hi, im new here, i did search (this site and the whole internet) for my answer with no luck. i know i have seen some sort of an adapter to bolt shaft mount rockers on to a head that had stud mount rockers. i have a fully built inside and out dart block 347 stroker twin turbo..... i have trick flow stud mount adjustable rockers on it now, that i cant seem to get adjusted right and theres no place in ohio that will do the job, so im wanting to switch over to non adjustable shaft mount roller rockers so i can just bolt on and go, and alll that without destroying a $16,000 engine. i have edelbrock e-street 2.02/160 heads with trickflow 1.70 stud mount roller rockers. any help would be greatly appreciated. oh an let me get my question right here, i need to know what has to be done to convert it from stud mount to shaft mount, and also does anyone know what the kits called?
DrGibs347 is offline
Old 07-01-2013, 09:25 PM
tinman
tinman's Avatar
All of the shaft mount rockers I've ever seen were made for a specific head.
I don't know of any non-adjustable type rockers for them either.
The first place I'd check with would be Harlan Sharp as they have been in the rocker arm business for maybe 50 years.
It could be that all you really need is a stud girdle for your heads and some good poly-locks....
tinman is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
dalefrancis88
09-11-2015 07:15 AM
spamedic
09-09-2015 12:15 AM
Quick Reply: how do i convert e-street heads from stud mount to shaft mount?
