still lean....have no clues???
RE: still lean....have no clues???
ORIGINAL: 90Mustangfan
41. and 91. are the hego sensor say its lean...I just freakin replaced the O2' sensor....also its not the timing, I know that for sure. yes the vaccum is good, at idle its about 10 HG of vaccum and when rev'd it goes up to 15- 20 HG of vaccum...the vaccum is good. I dont even know if the car is actually running lean, it runs very strong and sounds very good....also will an exhaust leak cause it to run lean, I have a exhaust leak out of the cats where the smog to connect to the cats...well there is no smog tube so theres 2 hole in the exhaust.
Ill try and plug it temporaily to see if the CEL comes on or not....but the sensors are before the cats...so how is fresh air going to go up stream the flow....IDK.....and my engine isnt stock its camm'd, stock heads though....It has comp cams cam in there and its a 306. my compression is 130psi, though Id add if it makes a difference. LOL. the vaccum goes down when I tap the gas, but soon after the vaccum is back up to normal....its not the vaccum thats fine...its not the egr system that all been replaced, and operates perfect the way it should.....
ShaneB26154
35
03-04-2021 04:05 AM
