Light white smoke from exhaust and heavy gas fumes
Old 08-18-2013, 12:57 PM
skins6983
skins6983's Avatar
Default Light white smoke from exhaust and heavy gas fumes
Hello,
I just bought a 93 gt with 86000 miles. I was told everything was original parts. So I went ahead and changed plugs, wires, cap and rotor, fuel filter, ignition coil, pcv Valve and filter. Ever since I changed everything out, I started to get a strong odor of gas inside of the car. And this morning I noticed light white smoke coming out the the tail pipes. I ran it for codes and got 21,44,57,87, 94 and 95. Any idea what could be wrong? It is greatly appreciated
skins6983 is offline
Old 08-18-2013, 02:14 PM
dawson1112
dawson1112's Avatar
Check grounds engine to body .. look for corrosion or broken/loose grounds.
dawson1112 is offline
Old 08-18-2013, 02:21 PM
dawson1112
dawson1112's Avatar
95 - Fuel Pump Circuit Open-PCM To Motor Ground is the likely culprit .
Old 08-18-2013, 03:17 PM
skins6983
skins6983's Avatar
I do recall that when I changed out the ignition coil, a wire hit the starter relay and sparked. Is the starter relay connected to the fuel pump in any way? Maybe I fried a wire it blew am in line fuse?
Old 08-18-2013, 03:40 PM
skins6983
skins6983's Avatar
*fried a wire or fuselink
Old 08-18-2013, 08:52 PM
89fiveeight
89fiveeight's Avatar
That would be a good place to start. The code is saying 'circuit open' that means its electrically open, like a blown fuse/link/ground. Something's not completing a circuit.
89fiveeight is offline
Diode Dynamics
28
05-26-2022 12:02 PM
Calizic
08-28-2015 01:46 PM
movielover40
08-27-2015 10:13 PM
overnight89
08-22-2015 09:02 PM
mweiland
08-16-2015 10:59 AM
Quick Reply: Light white smoke from exhaust and heavy gas fumes
