Dropping the tank without removing filler neck?
Old 03-15-2014, 02:03 PM
GoshenGT
GoshenGT's Avatar
Default Dropping the tank without removing filler neck?
Got a 1990 GT. About to start the process of dropping the tank and I heard that you have to replace the grommet anytime you remove the filler neck, I previously replaced it and wouldn't mind dropping the tank without removing the neck, is this possible? Thanks in advance.
GoshenGT is offline
Old 03-15-2014, 03:03 PM
dawson1112
dawson1112's Avatar
possible ? probably but likely difficult.
I had never heard that you necessarily need to replace the gromit, its a good idea if its an old one though since the tank has to come down any ways to do it.
I would think if you just replaced it not long ago then it should be fine.
dawson1112 is offline
Old 03-15-2014, 04:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no need to remove filler neck, I drop the tank and slide it towards the driverside and never have had to remove the filler neck
mjr46 is offline
Old 03-15-2014, 07:49 PM
Krochus
Krochus's Avatar
I tried and tried and I couldn't make it happen on my notch. I had to pull the filler
Krochus is offline
Old 03-16-2014, 07:40 AM
9redfox3
9redfox3's Avatar
1,2,3 pretty straight forward.........
9redfox3 is offline
jwog666
12-27-2021 08:09 PM
Granatelli Sales
01-20-2020 12:34 AM
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Dropping the tank without removing filler neck?
