before buying it ask if its a track heat or street heat. if track dont even bother unless you have a built motor that can actually pull hard to 6500 rpms
I have the same intake(not black) on my '86 GT. I had major head ache with the install of billet fuel rails! The driver's side rail had major clearance problems with the distributor. I had to clearance alot of material off the front corner of the rail. I believe that the problem was caused by the forward angle of the front runners. As opposed to the stock intake. I even purchased the Behind Bars Fuel Rails with the 45 degreee front inlets. They still interfered with the weld beads. If your running the stock fuel rails, I don't think you will this problem. Good Luck!!
hey i am also looking at a intake trick flow track heat off a friend off his fox that will be going on a 95Gt will it work if doesn't have the EGR spacer i haven't seen it yet so i am not sure if it has it or not
