reseting and re-learning my A9L
Just disconnect the battery for 5-10 min.
Reconnect, start car and drive it. That's it.
What's your car doing that makes you think the ECM has bad info? Or is this after a new modification you made?
Either way, good luck.
i have done some new mods. Changed fuel injectors,maf,cold intake. Also my car didn't come with the A9L. I was told you have to disconnect battery with head light switch on for 30 min to truly reset the computer. Then run through a series of different processes to learn it
disconnect battery with headlight switch on for 30 minutes
start and idle for 1 min
shut of 10 sec
start engine with all acc. on and idle for 1 min
turn everything off and wait 10 sec
start and hold at 2000rpm for 1 min
shut of for 10 sec
start engine with all acc. on at 2000rpm for 1 min
shut of 10 sec
shut of for 10 sec
do a base idle reset after disconnecting battery.....that is if you are trying to reset idle...if not just go drive the car for 20-30 min the KAM will update enough to learn drivibility in that period and will continue to do so the more it is driven under varying circumstances
yourmom6990
09-14-2015 10:52 PM
TfcCDR
09-14-2015 12:08 PM
