cam selection
I am currently running the E-cam in my 347 stroker (built on a budget). But, I am looking to put a new set of heads and a new cam in my car to release some more power from it. I had made a post before and someone commented on my cam selection and told me about lobe seperation and some other specs. What is the best lobe seperation for a stroker motor, I know the e-cam is 110 degrees and I believe the person said less for a stroker motor but i am not sure. Anything will help.
i have been doing more homework and found that it is a good idea to get a cam with more exhuast lift due to that fact that i have a storker motor. and one more thing i am running 11.5:1 dome top pistons so i wll need to check my piston to valve clearance first before i go out buying a cam because i have 1.7 roller rockers and dont want to slam my valves into my pistons
Id take a look at the Trickflow Stage 1, I know thats what Im gettin once I get a cam. I dunno if the lobe seperation on it is good for a stroker motor or not tho or if it matters. But it rates in at .499/.511 so it has more exhuast lift if thats what your looking for.
I am running the Stage III Trick Flow cam in my 347. I have 10.5 to 1,H-beam rods,steel crank,main girdle,fluid damper,Avenger-Heads w/ stasge III port/polish,1.7 roller-rockers,Trac-Heat intake w/36 lbs. injectors,70 mm throttle body,Pro-M -meter and Aeromotive complete fuel system!!! The cam specs. are : 298/310 dur. and .574/.595---------Good Luck!!!!!!!!!!
junior04
Sep 28, 2015 10:53 AM
