CLUTCH ISSUE.....
You have to push the pedal down and then hold the quadrent from moving with a screw driver or something then slowly lift the pedal up and you will hear it click. 1 click at a time until you can easily bring the car into and out of gear easily. If you take out to much slack it can cause the clutch to slip so 1 click at a time until you get it where it needs to be. Usually 1 or 2 clicks is all you need.
junior04
09-28-2015 11:53 AM
ccdguy
09-19-2015 06:20 PM
